Salta al contenuto principale
Il controller PS4 modello CUH-ZCT1. Rilasciato nel Novembre 2013 dalla Sony Computer Entertainment, la sostituzione della batteria da 3.7V di questo "six-axis" non è una riparazione complicata (N.B.: La guida di smontaggio NON è per questo modello)
387 Domande Visualizza tutte
What is the mAh battery specification for CUH-ZCT1U?
Hi
I received a dualshock 4 which I'm currently disputing with my bank to process a chargeback claim. I have some proof from Sony that the inside is not genuine but have been as vague as possible.
Can you clarify what mAh the battery should be in this model?
I know the Sony website says 1000mAh for Dualshock 4, but it doesn't clarify this is the same for all generation.
I have a silver shimmer type foil covered battery with a yellow transparent perspect type strip where the cables come out.
Only text on the battery is:-
-YMD 603040
+3.7V 600mAh
There's no Sony logo or brand on battery
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
JoB it should read 3.65V 1000mAh It is easily possible that your DualShock is a factory rebuild one and therefore the battery might be different. Of course it is also possible that it is a used controller. ....
Punteggio 1
3 Commenti:
I have the same issue but not only that but my r2/l2 are way too sensitive and have dead zones. For some reason when i plug up the head set it is amped up way too high and the light for when it charges is yellow instead of orange.. cant return it because the seller on ebay does not except them. I bought it “new” but i am doubting the credentials.. help!
da
I am also having the same issue
da
The dead zones are messed and cant be fixed in game and after charging overnight there was a blinking red light and the controller would no longer turn on, I recently opened the controller and the battery reads -FEX 603040 3.7V +600mAh 1911 on a silver foil on a transparent yellow covering. I cant replace it with another battery because the motherboard battery plug in size is different to the original battery. I dont know what to do anymore PLZ HELP!
da
Aggiungi la tua risposta
JoB sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 438
