Salta al contenuto principale
The Wonderboom is a Bluetooth portable speaker from Ultimate Ears. Released in 2017. Model number: 984-000839.
Speaker turning itself off
I just got a new UE wonderboom speaker off of Amazon, fully charged it, and now when I try to play music through it it will turn itself off after playing for a few seconds. I’ve tried a default reset and removing the device from my phone, any ideas on what to do?
Questa è una buona domanda?
Punteggio 7
14 Commenti
yeah i get the exact same thing here. exactly 45 seconds after its been paired it will turn off. even though there is music playing. this happens on any device i pair it with.
da
Hi, did anyone get a resolution for this?
Thanks
da
Bro guys mine does that too where we droppin
da
Is there a real fix for this? Mine does it too. I was thinking battery life - trying to recharge via usb cable now.
Even pressing the ‘+’ and ‘-’ simultaneously doesn’t tell be battery level like it’s supposed to.
da
mine does this too, does anyone know a way i can contact someone at wonderboom to maybe replace it?
da
Mostra altri 9 commenti
Aggiungi un commento
14 Risposte
Risposta Più Utile
Here it is how to solve it:
Long press the power on button for at least 10 sec and then it will work.
If it still continues disconnecting then plug the charger and turn it on and then disconnect the charger.
If it still continues then an update from the company must be released to fix it. You cannot do anything else
Punteggio 4
5 Commenti:
I have the same problem, long pressing the button did nothing besides turn it on and off. When I plug it into the charger, the lights stop working, and I don't know if it is even charging. If I turn it on while it's charging, it makes the turn on noise and only lights up when I unplug it, but still gives me the same problem
da
This helped!
da
Worked for me thanks! Try doing it 3 times if it didn’t work the first time.
da
Could it be a shut off circuit when the speaker is to hot or to loud , like it might blow?
da
Sorted it for me. I’ve been bartering that for about 6 months. Thank you 🥰
da
Same with mine and friends of mine. Both UEs switch off in few seconds after power on. But both work fine if usb charger is plugged in. Guess something wrong with power controller or internal software. Battery is fully charged, and units are updated.
Punteggio 1
2 Commenti:
My megaboom 3 turns off afyer exactly 20 mins
da
My UE switches off every 15 minutes. Turning power off for 10 minutes does nothing.it worked normally for years. Can we turn back update? If so, how?
da
Mine has also been doing this when I play music from my phone onto my speaker. So when it stopped its like it connected to another device so I opened my laptop because that’s the only other device that I have connected to my speaker before and I started playing music off it and it came through my speaker and hasn’t stopped playing. So if you don’t want to play music off that device maybe go to settings and press forget this device.
Punteggio 1
1 Commento:
Culprit on my end (Wonderboom 2) was also my laptop connecting to it without my knowledge. Removed from devices and the speaker stopped pausing every 5 minutes.
da
Hi @greenteaa ,
Does it turn off (power off) or does the music just stop playing and the power light (and BT light) are still on?
(It should turn off after 15 minutes if no music is detected, not a few seconds with music)
In any event as you have just bought it consult the manufacturer's warranty statement that came with the speaker as to what you have to do to make a claim for a manufacturer's warranty repair, replacement or refund.
Update (01/12/2018)
Hi @greenteaa ,
As a last resort, if possible try pairing it with a different BT source (another phone perhaps) to eliminate the remote possibility that it is your phone (can't see how but it doesn't take long) and if it still fails then get the speaker replaced under warranty.
Punteggio 0
7 Commenti:
It completely powers off
da
In mid song or when its just sitting?
da
Both, it will just shut off after about less than a minute of being on
da
Same problem here. Just turn off asap it connects to Bluetooth or play song.
da
I have the same problem! So annoying
da
Mostra altri 2 commenti
just replace it by warranty
Punteggio 0
1 Commento:
How long is the warranty
da
Only happens when it is plugged in and charging ( playing ) and after the power had gotten low enough for the red light to flash. So possibly just needs more of a charge before playing.
Punteggio 0
if you have simcard with t-mobil it will only play for a few mins then turn off ,on pandora i have tablet with att simcard works great i have a samsong cell with t-mobil service it dont work well at all so checkwith another phone with different sim card good luck took me 28 hrs to get it right
Punteggio 0
I also have a wonderboom that I fully took apart to find a solution but the only way I can get it to work without turning off 5 sec after If it’s only plugged in and playing while charging
Punteggio 0
3 Commenti:
Solution found!!! At the head top of the speaker give it a little knock. If it still.doesnt work hit it again. If still not hit it harder. Thats how i fixed mine and now it has never had a problem. That hit on the speaker also fixed another speaker that went off...
da
how hard do I have to bash it exactly?
da
I solved mine by turning on "Bluetooth standby"
da
This happened to my speaker. Hold down the power button and the volume down button for a few seconds until it makes a sort of beeping sound. That should reset it, which fixed it for me
Punteggio 0
Have you guys checked on the UE app if the “auto sleep on battery” setting is on never?
Punteggio 0
So I had the same problem. I would turn the wonder boom on, start the music on my phone and walk away with my phone to sit probably 10 feet away or so. 30-45 seconds later it would turn off. So, I unplugged it from the charger, brought it over to the couch with me and have had no issues. I’m thinking that the blue tooth is being interrupted. I’ve had no problems since as long as I don’t go too far away from the device.
Punteggio 0
I had the same problem, tried everything mentioned. I Hit my wonderboom a few times and suddenly when turn play it worked!
Punteggio 0
My Boom 3 speaker would turn off immediately (1-2 seconds after turning on) despite being fully charged. It was paired with my computer (which I didn't need it for) and my phone. I unpaired it from my computer and now the problem seems to be fixed.
Punteggio 0
1 Commento:
Had the same issue and it works with knocking ob top of boom. Don't know why it worked and question is how long will it work. I tried the recommendation here with the knocking. After turning it off, I knocked around the power button with my knuckle and then turned it on and the device stayed on. I suspect a mechanical problem with the switch, which doesn't engage or disengage properly due to pressure from the housing.
da
I insist you get the app on your phone I had the exact same problem but once I got the app it has fixed itself kind of annoying but oh well
Punteggio 0
Aggiungi la tua risposta
Anna M sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 83
Ultimi 30 Giorni: 351
Tutti i Tempi: 79,503
