Salta al contenuto principale
The DZ09 is a Chinese smart watch with basic features and the ability to make calls. These can be as cheap as $10! (Yes, you read that correctly!)
90 Domande Visualizza tutte
Watch stopped charging. Can we change the battery?
Can you change the battery in a smart watch?
Questa è una buona domanda?
Punteggio 3
1 Commento
Replace the battery because battery is not working
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi @twin ,
Here is a video that shows how to access, remove and replace the battery in a DZ09 smart watch.
Here is a link to just one supplier of a replacement battery. It is not a recommendation to use them. It is shown to give an idea of the cost of the battery. There are other suppliers online that may suit you better. Just search for FYM-M9 battery to get results.
Punteggio 3
  1. Bro first you check your smartwatch charging port and charger. If the charger output is less than 5 watts then it will not charge. If still it is not charging then you can change the battery. The battery model is LQ-S1 and it'sive is 150-200 rs on Amazon
Punteggio 0
Aggiungi la tua risposta
Shirley Worthy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,679
