iPhone 6s screen cable ribbon sparked/smoked
I replaced the screen on my iPhone 6s. After I attached the first ribbon cable to the phone, the second cable touched the pins and sparked and smoked for a second. I proceeded to finish, and the screen is now not turning on....What do I need to replace?
Questa è una buona domanda?
5 Commenti
UPDATE: The phone works, but just the display is not projecting an image. I can tell this because when I plug it in, it "dings", and the phone is vibrating.
da William Falb
You did not disconnect your battery before removing and installing the new display, the backlight fuse has blown, possibly the filter, diode, or IC damage.
It can still be repaired :)
da smartfonefix
You will need to test the backlight pins and check resistance to ground by using a multimeter, find out which pin has a damaged line, start from the top right and move to the left on the LCD Connector, there should be a solution on google, just type in 'iphone 6s backlight solution' it will show you the line to each pin. Check each component and see which part is damaged. It is not an easy do it yourself repair if you are not a microsoldering specialist.
da smartfonefix
Thank you so much. Any idea how much/how long these microsoldering repairs take, because I am not experienced.
da William Falb
Hey guys & gals! I have this issue too but mine never sparked. Also the screen has come fully back on for 1 - 2 seconds 2 times within a day of each other! I ordered a new screen but that hasn't worked. What fix do you recommend?
Thanks all!
da Andrew Atchison
