My LG dishwasher shows a error code IE
My dishwasher starts and immediately displays a IE code ? How should I sort this - plus it’s a inbuilt washer LG Direct drive
Questa è una buona domanda?
Dishwasher by Bosch identifiable by the model number SHU5315UC-06 or SHU5315UC/06.
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. This time of year it can also be a partially frozen water pipe. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
UPDATE
Cause 1
Water Inlet Valve
The water inlet valve opens to allow water to enter the washing machine. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
Cause 2
Low Water Pressure from House Supply
The home water pressure might be too low. The water inlet valve requires at least 20 psi to function properly. Check the water pressure to the valve to determine if it is sufficient.
Commenti:
How can this be resolved ? I tried turning the knobs to the water inlets and they are fine. Also the water in the house is fine too, should I get somebody to check the water inlets ?
da Purva
I had reached under front panel to dry up water after using wrong detergent. This fixed AE error but now have IE. Could I have jarred loose a wire or something when drying?
This can also be caused by low water table if you have a well.
da Gina Potkul
Check the filter of water solinoid valve
Commenti:
Water pressure is ok inlet valve is ok but IE error not solved
Hi @Bandopant Chincholkar,
What is the model number of the dishwasher?
da jayeff
Ultime 24 Ore: 44
Ultimi 7 Giorni: 251
Ultimi 30 Giorni: 1,067
Tutti i Tempi: 65,899
we replace the water inlet valve the same error comes on le
da charles.harris15
I'm on well water and I must clean inlet screens regularly to resolve there are usually two screens each side works for me
da Ted
My dishwasher starts run smoothly i set 45mins program it works around 36mins after that spins process that time only displays a IE code ? How should I sort this
da yogeshram
Try cleaning intake screens there are 2 on hot and 2 on cold where the hose attaches
da Ted
We just replaced the water heater and need to purge the line to the dishwasher. Is there a dishwasher function, or workaround, that will simply open the lines?
da Frustry Trier
Mostra 1 altro commento
