Salta al contenuto principale
Lo smartwatch Apple di terza generazione, con connettività cellulare opzionale, rilasciato il 22 settembre 2017
197 Domande Visualizza tutte
Corner of screen shattered
I was stoking a fire, with a metal grate around it. I accidentally bumped into the grate which caused me to jerk my hand away, and in doing so I hit the corner of my Apple Watch on a piece of metal with considerable force resulting in a pretty nasty shatter of about a quarter of the screen. The only issue is that I don’t know if I damaged anything internally, or if it was just the screen because the affected areas seems pretty deep.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
jake apostolu the only way of determining that would be by starting with replacing the screen. Although not a guide, this teardown Smontaggio Apple Watch Series 3 should help with that. Once you've managed to change the display, re-evaluate for further damage.
Punteggio 1
Aggiungi la tua risposta
jake apostolu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,142
