Salta al contenuto principale
Repair guides and support for your LG TV.
TV not responding to remote and physical buttons
Hi
Today my TV a LG 47LM669S stopped responding to the remote control and also the physical buttons weren't responding.
After a while I couldn't turn on the TV anymore.
I disassembled it and took the physical buttons board out and now it seems to be working again with the remote.
Is it possible that the physical buttons unit (I don't know the right name for that) may be broken, we don't use it at all...
By looking at its PCB all seems fine not burn or discoloured parts, what can be a good test to make to check if the part is defective?
Can the IR board be faulty?
If the part (seems to be GP4 Control) is defective where can I find a replacement part in Europe?
Here some pics of the part:
Best
Vlad
Questa è una buona domanda?
Punteggio 6
4 Commenti
my own stopped working all of a sudden bot the physical button and remote control
da
I have the same issues but some remote button work but most don't. None of the buttons on the unit work at all. Please help!
da
I have exactly the same issue with a 22TN410 but I can't figure out how to get the back off, it has no screws and no obvious lever points.
da
Did u get the 3 by the aux input?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
The part is available on Ebay (it is located in the U.K.)
Just search online using the board number (EAX64466302) for other suppliers if this seller doesn't suit you.
The only test perhaps is to use an Ohmmeter and check if any of the buttons is s/c (short circuit) or low resistance. Although perhaps not because if it was then you would think that there would be a indication on the screen such as a permanent Volume level display in the case of a faulty Volume button for example. Maybe more than one button is faulty which would confuse the processor as to what to do and therefore it would do nothing. Just a thought.
I don't think that the IR is faulty because it works OK when you disconnect the button board.
Punteggio 4
Risposta Più Utile
@Gordon Boone
Try removing the batteries from the remote control and check if the TV control buttons now work.
If no good, disconnect the power from the TV, remove the back cover and locate the TV control button board. Disconnect the cable that goes from the board to the mainboard. It may be easier to do this at the mainboard end. Check the cable plug first before removing in case there are latches, locking bars, clips etc. If none obvious gently pull the cable out by the plug and not the wires as you may pull them out of the plug.
Replace the back cover and then reconnect the power to the TV. Then try using the remote control to operate the TV.
What is the model number of the TV?
Punteggio 6
6 Commenti:
Hey, just want to say thanks! Had this problem with my TV and thanks to your responses I was able to fix it. <3
da
Thanks my buttons on the tv have a problem and now I disconnected them the tv works fine with the remote I just hope I don't loose the remote now lol
da
32LH30-UA Can you help me? I'm at the point of having to mess with the control panel I have located the two screws but don't know where to go from there on this model! Thanks!!!
da
@tvwontwork
If there's a cable from the control panel, follow it back to where it connects on the mainboard and just disconnect the cable there.
If the IR LED is also on the control board then unfortunately you won't be able to turn it on using either the buttons or the remote.
You may need the schematics to find out what's wrong
da
So disassemble the two screws, look for a cable, disconnect that cable, and it should work if it's going to work? My IR LED is on the bottom of the TV so I'm praying it's not hooked to it as the control panel is on the side. Thank you so much and I will look at those schematics! Thank you for helping us not buy new TVs if we don't have to! Mine worked fine 2 days ago and yesterday it quit, at least this gives me a shot!
da
Mostra 1 altro commento
Aggiungi la tua risposta
Vladimir Knobel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 47
Ultimi 30 Giorni: 188
Tutti i Tempi: 47,842
