Bass not working well on lower volume
So i Just bought the skullcandy crusher wireless and am really happy with it, hut i seem to have this one porblem, whenever i listen music on lower volume, around 25 % the bass tends to Just turn off randomly. And will only work well with the bass slider on or above 50%. When i lower the bass it works for a little While and then it Just seems to turn off, and when i push it up halfway it Just turns on again. Again this is only on lower volume, on higher volume it workshop flawlesly.
Questa è una buona domanda?
8 Commenti
Hi,
Does it do this when you have the charger connected and switched on?
da jayeff
The Headphones dont work at While charging
da Erik Bobeldijk
I bought the headphones on 2018.02.20 and I have exactly the same problem. Were you able to fix it somehow?
da Marek mspeedo
I have the exact same problem, exactly this. Finally found someone with the same issue. Did you figure anything out?
da J L
I bought mine just 12 days ago and I have the same problem. My return/replace period just expired and now I must go through the hassle of claiming the warranty.
Is there any solution for this without claiming the warranty?
da Reggie Ivaylo
Mostra altri 3 commenti
