Salta al contenuto principale
Lanciato da Samsung a marzo 2016. Modello SM-G930.
425 Domande Visualizza tutte
Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
Questa è una buona domanda?
Punteggio 7
Aggiungi un commento
3 Risposte
Risposta Più Utile
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
Punteggio 2
7 Commenti:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
da
adb shell dumpsys iphonesubinfo
da
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
da
Removed comment.
da
Mostra altri 2 commenti
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
Punteggio 1
1 Commento:
Should the phone be off or on ?
da
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
Punteggio 0
Aggiungi la tua risposta
Scott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 78
Tutti i Tempi: 11,012
