Salta al contenuto principale
Lanciato da Samsung a marzo 2016. Modello SM-G930, Versioni: G930F (Globale); G930FD (Globale; Sud-est asiatico); G930W8 (Canada).
Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
Questa è una buona domanda?
Punteggio 10
1 Commento
this is lwky a good question, I have the same problem, my best friend gave me her old Samsung Galaxy s7, and she kinda just gave me the password and got tfo so I looked up a ton of shi and the FRP lock is genuinely killing my soul right nowwwww.
da
Aggiungi un commento
3 Risposte
Risposta più utile
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
Punteggio 3
7 Commenti:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
da
adb shell dumpsys iphonesubinfo
da
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
da
Removed comment.
da
Mostra 2 altri commenti
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
Punteggio 1
1 Commento:
Should the phone be off or on ?
da
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
Punteggio 0
Aggiungi la tua risposta
Scott sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 9
Ultimi 30 giorni: 43
Tutti i Tempi: 12,900
