Salta al contenuto principale
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Domande Visualizza tutte
Why do I have a exclamation mark on battery symbol,how can it be fixed
I have a htc one m8 and all of a sudden a the battery will be fine but then it changes to a grey battery with a red exclamation mark inside and I don't understand what it means or I don't know how to fix it and the phones only on 16%
Many thanks
Need to know ASAP
Questa è una buona domanda?
Punteggio 3
1 Commento
If it's a new battery, be sure to check and tighten the screws that connect to the battery. Put it back together and plug it in to see if that fixes it. It fixed mine! My battery had a 50 percent charge from manufacturer when I finally got the phone to turn on.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
This means the battery is faulty or not properly communicating with the phone's logic board properly.
I would recommend replacement.
Here is a teardown guide.
HTC One M8 Battery Replacement
Punteggio 6
Aggiungi la tua risposta
Chloe Walden sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 40
Tutti i Tempi: 24,003
