There was water in my TV (condensation!) and now there are stripes..
Hi there, due to some strong temperature changes my TV got condensation in it; it was actually dripping out of the bottom! I've been drying the TV out, carefully blow drying on cool and leaving it in a warm room but there are now thick vertical stripes down the left hand side of the screen. Is this TV fixable? Should I take the back off and if so how do I do it? Seems a shame to throw it away, its good TV.
It's a
Sony Bravia KDL-40EX724
Many thanks.
Questa è una buona domanda?
7 Commenti
@gabeuk that sounds like some heavy duty humidity. Brazilian Rainforest? Anyhow, yes you will have to take a look at it. Let us know what exact model your TV is and post some good images of what your screen shows with your question. That way we can see what you see. Use this guide Aggiungere immagini ad una domanda for that. It will also help us to try and find a solution for your damaged TV
da oldturkey03
I've finally uploaded a picture! Actually I think the water came into the TV via the aerial cable....
da gabe
Ok I took the back off and hair dried it (on cool) I took out video lead and dried that and reseated it.
Sadly still stripes. Any ideas as to what I could try next? Maybe something bust with the water?
da gabe
Unfortunately it could be power related or component related....all modern TV sets are modular in design...which basically means each panel does a set job...and if a component blows...then the engineer "swaps " that module ...because it is easier than trying to detect and replace very tiny components.
My guess it is the video board which is sometimes separate but usually on the main board.I assume you have dried ...cleaned and reseated ALL the connections....and looked around the board for signs of burnt areas, or browning....
A tv engineer would be my next thought ..but if you are adept at fixing things ..Take the model number ...and search eBay and Amazon for the main logic board....they are usually inexpensive...
da john cordey
Thanks I only dried and reseated the pont that looked easiest to do! Maybe I'll have another go....
da gabe
Mostra altri 2 commenti
