Salta al contenuto principale
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
203 Domande Visualizza tutte
Blinking red light and flashing backlights but TV won't turn on.
When connected to power, the red power light continually blinks and the tv flashes but nothing is displayed. I have already replaced the power supply board and the main logic board but the same problem persists. Any ideas on what I should try next?
Questa è una buona domanda?
Punteggio 0
2 Commenti
mine has the same issue, I've replaced main board and logic board as well as the cables that i got from shop jimmy.com. no luck :-{
da
i plug in my 39" Samsung led tv . red light blinks at the same rate the black lights are flashing like a camera. Will not turn on.
If i unplug the led back lights the Tv will turn on, Sound, if i use a flash light i have a dark picture.. Then if i plug in the led back lights in the tv turns off.
What is my fix? bad led? bad power source?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@inktank when you say "tv flashes" and you mean the screen then it could be an issue with the LED array. Post some images of all of the boards on your TV and post those with your question. Use this guide Aggiungere immagini ad una domanda for that. It will allow us to see what you see.
Punteggio 1
Aggiungi la tua risposta
davidborder sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,740
