Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
FaceTime Camera do not work after changing Flex
Hello everyone, I have a problem With an iPhone 5C.
The Facetime camera does not work on any app (Photo, Facetime, Snapchat...)
I've change it and it still doesn't work with a ne piece (I've tried 5 different flexes)
I tried to reset the settings, reset the devices and it still doesn't work.
Do anyone had this problem ?
Thank you !
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Sostituzione fotocamera anteriore e cavo sensore iPhone 5c
Use this guide to check your sensor cables and for help if they need to be replaced.
Punteggio 1
Please remember to ensure all connections are snug, and you do a hard reset after each replacement.
if you have tried 5 flexes from a trusted supplier, then i would follow the steps below.
1) Try replacing the other camera: the circuits in iphone cameras are linked, and sometimes, a small discrepency in the other camera can be the cause of a fault in the one you are struggling with.
2) Damaged or missing components: Using a microscope for this helps. scan the board for missing components, or scratches and chips out of ICs, and coils.
3) Reflow the FPC Connector on the board: Make sure there are no damaged pins, and reflow the connector to ensure connection to the board.
4) use a multimeter to check for continuity of the coils (Resisters, inductors, caps, etc) around the connector for your camera flex, and replace any that are not getting a full circuit.
Punteggio 0
2 Commenti:
Thank you very much, I try it and I send you a feedback !
da
anything further than these, will be a problem with the Front Camera Control IC. this replacement requires a board diagram, with labels pointing directly to the component. i tried a quick google search, and couldnt find an image for you. there is a possibility that someone else on here has access to the OEM drawings.
da
Aggiungi la tua risposta
Aurélien Patricio sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 66
