Salta al contenuto principale
Repair and disassembly guides for Apple Time Capsule wireless network devices.
147 Domande Visualizza tutte
What adhesive do I use on the rubber cover?
I followed all of the steps to replace the hard drive and everything worked out great. However the rubber cover on the bottom does not want to stick back all of that well. Following the guide I was able to peel back the the cover to just where the screws are located and never removed the entire cover.
I was wondering what others had used, double stick tape does not seem sticky enough to me. I have tried using a hair dryer on a low to medium setting and it did fairly well.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
I'd say rubber cement would probably be a good choice, as it is only semi-permanent but still holds well. Remove the old adhesive to make the surfaces as smooth as you can and then paint a thin coating of rubber cement on the inner side of the cover as well as the face of the case that it mates to. Let the rubber cement dry for a while, then press the pieces together. Just make sure you get it aligned the first time, it produces a surprisingly strong bond.
Punteggio 5
4 Commenti:
+ works for me
da
+ and me as well
da
Thanks I will try that. I wonder if that is what Apple used in the first place as it was really stuck on when i tried to remove it.
da
I've always wondered what the Apple OEM adhesive is as well. It seems like they use the same semi-permanent adhesive somewhere on nearly every device that they manufacture.
da
You should try this
http://www.gorillaglue.com/glues/supergl...
or this
http://www.supergluecorp.com/super-glue/...
in my experience rubber cement never works on plastic.
Punteggio 0
2 Commenti:
The time capsule has a rubber bottom cover that mates up to a steel plate, so rubber cement should be OK for this application. I'd be leery to use super glue for this because it produces such a permanent bond that you'd be screwed if you had to take the device apart again in the future.
da
the only thing I use super glue for is to repair skin lacerations. It's a PITA if you ever have to replace anything again. Just my 2 cents
da
Don't glue it back on. It's part of the problem.
Reassemble the Time Capsule with holes in the rubber and metal base for ventilation. Drill holes through them before reassembly. Double sided tape works good enough to hold the rubber on and allows easy removal if it needs to be opened again for HDD access.
Punteggio 0
Aggiungi la tua risposta
Jhan Jensen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 5,229
