Salta al contenuto principale
The flashlight doesn't work
I followed the 'problem' steps from the manual, but the flashlight is still not working.
before it stoped working, from time to time the flash worked, making a popping sound when making a picture.
I think, it is broken and needs to be replaced. but how, do I do that? and were can I find a new flasher?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Your best bet it to put a watch on eBay for a "spares or repair" camera of the same model but with a different fault. It should then be possible to swap out the flash module. You can practice disassembly on the one from eBay before attempting yours.
BUT: make sure you understand the danger from the flash capacitor and how to avoid it - this can hold a charge at a dangerous voltage for many hours, or even days, after being switched off.
Punteggio 2
Aggiungi la tua risposta
olé kike sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 31
Tutti i Tempi: 558
