Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
797 Domande Visualizza tutte
Why wont my iPod fully turn on
my 5th gen 30gb ipod (model # A1136) will not turn on. when plugged in it shows the "please wait, very low battery" sign for 1-2 minutes, then tries to turn on and only comes up with a screen showing a little ipod with a sad face saying to go to apple.com/support/ipod. how can i fix this??
Questa è una buona domanda?
Punteggio 1
1 Commento
It is interesting to note that the message "please wait very low battery" is displayed even if the battery is physically removed.
Also, the screen showing a little ipod with a sad face saying to go to apple.com/support/ipod is displayed even when the hard drive is physically removed -not connected at all.
So the most logical explanation is that the drive is not responding -or booting up, and therefore it makes no difference weather it is connecetd at all to get that message.
My iPOD clicks when trying to boot-up.
I will replace the drive and let you all know if it is fix.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
chris, you may actually have a low battery. Does it still charge, have you replaced it at anytime? It is relative easy to do and here are the instructions The battery is readily available here Make sure that when you disconnect that you pull the clip on the connector straight up, it is easy to tear the connector of the logic board if you apply to much sideways pressure (been there, done it) and make double sure that your cable is inserted deep enough. Good luck and let us know how you are progressing.
Immagine iPod Video 30 GB Battery
Prodotto
$13.99
Punteggio 2
1 Commento:
+ that might work too
da
Risposta Più Utile
Go to www.apple.com/support/ipod. Follow the directions. Just kidding. Actually go here and follow the directions: http://support.apple.com/kb/ht1320
Punteggio 2
My 5th gen suffered the same fate, can you hear the hard drive spinning up or is it clicking with a low whir ???
I suspect your hard drive has failed
iPod 5th Generation (Video) Hard Drive Replacement
Punteggio 0
Aggiungi la tua risposta
chris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 8,279
