Salta al contenuto principale
Questo è un controller basato su touch-screen associato con la console videogiochi Wii U. Fu rilasciata nel 18 novembre del 2012 ed è disponibile nei colori bianco o nero. Numero del modello: WUP-010(EUR/USA/JPN)
gamepad working no picture(no visual damage) after it fell down
everyting seems to be working exept no picture on gamepad ,buttons are working.lcd has no visual damage.just replace the lcd or could it be something else ?
Questa è una buona domanda?
Punteggio 0
1 Commento
turns out we where both right ,a connector was a little bit lose ,fixt it to see when the display was on ...it had a little crack so replaced it ,now working good,
thanks for the help
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
it's possible a connector came loose. I would take it apart, and re-seat any connectors on the inside. If the problem still exists, then proceed with an LCD replacement.
You can follow this guide to get to the connectors Sostituzione schermo LCD GamePad Wii U
Punteggio 1
1 Commento:
i will have it a try ,seems unlikly that a connector came loose but you never now ,i have to open it anyway to replace the screen
da
Agree with David if that doesn't work then put a new LCD on it.
Punteggio 0
Aggiungi la tua risposta
clarysse bart sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 722
