Salta al contenuto principale
Repair information for the Samsung 55" Smart TV with model number UA55JS8000 or UA55JS8000W.
Two red line on the screen
Hi dears,
few days back i found a red line on my Screen which not effect the pixels and appear only in any white background.
The support center they said i need to replace the screen
Is there any solution for that?
help please.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
@alitawash those do like a TAB error. That is where the bond between the thin ribbon cable and the panel fails. You can try and apply some pressure right above the lines and see if they then disappear. Of course it is best done with the back of the TV removed. Here is an image to show you the TAB bonds.
There is really no fix for it since it requires a special repair. Sometimes it can be temporarily be resolved by continuing to apply pressure to the bond with some tape etc.
If you can, take some pictures and post those with your question. That way we can see what you see. Use this guide Aggiungere immagini ad una domanda for that
Punteggio 1
Aggiungi la tua risposta
alitawash sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 684
