Salta al contenuto principale
Part Number: DD11210 The TotalPond pump, which was designed for water gardening enthusiasts, circulates 210 gallons of water per hour, maintaining the ecological balance of small ponds. It is used in water garden less than 3 feet by 6 feet ponds and waterfalls to provide streams of water up to 7.8 feet high.
Need screw on flow regulator on throttling valve for TotalPond pump
I have a 800 gph TotalPond pump that is missing the small screw-on flow regulator that screws into the Throttling Valve. Where can I buy one?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @mrditto ,
It might be easier and quicker to contact TotalPond direct and find out if the part is a) even available and b) where to get it from if it is.
Punteggio 2
Aggiungi la tua risposta
Ditto Bolinger sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 255
