Salta al contenuto principale
L'evoluzione della classica automobile di John Cooper, creata da BMW.
13 Domande Visualizza tutte
heating issue mini cooper 2005
even, fan, thermostat are correctly operating and coolant liquid is fool, the temperature is high.
could you, comment about the common problems and the respectly solutions for this issue,
thanks a lot.
Juan José Blas
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi Juan, if the thermostat is operating normally then there could be air stuck in the system which is what's causing the overheating. I would have the system bled.
Punteggio 1
Juan Blas make sure that your radiator is not obstructed by anything, that your fans come on appropriately. After that you'd possibly be looking at water pump issues.
Punteggio 1
Aggiungi la tua risposta
Juan Blas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 554
