Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Can I switch an iPhone 6s display to another iPhone 6s display?
So if I wanted to replace my iPhone 6s display, could I just get another iPhone 6s display and switch them, but also use the same original home button? Are there any other steps I need to know other than knowing how to take out the display and reattaching the display? Do I need a heat gun or blow dryer or not? I'm doing this because my screen is broken and I already ordered a new display to replace...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You can do that, but your finger print scanner will not work. No apple pay : ( The motherboard is married to your button. You'll want to use yours if you can.
Punteggio 0
2 Commenti:
Okay thanks a lots.! I was able to switch the displays and keep the original homebutton.
da
Awesome man! Glad I could answer your questions!
da
Yes you can just swap out the screen it usually comes with tools, but I like to use a spudger to open the phone. I advise using a little heat near the home button connection. The flex cable is pretty flimsy and sometimes the adhesive can have a snug hold. You do not want to damage the home button on disconnection. I strongly advise using one of the step by step guides on disassembly and putting your screws in order. Let me know if you have any other questions man.
Punteggio 0
1 Commento:
Another question, I was curious if it was possible to just switch another random iphone 6s homebutton to replace the original homebutton?
Thanks!!!
da
You can replace it with this tutorial Sostituzione schermo iPhone 6s
Punteggio 0
Aggiungi la tua risposta
Luke sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 80
