Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Issues with aftermarket 6s screens and iOS 11
In work today we found an issue with aftermarket 6s screens and iOS 11, the touch is dead, no life in the digitiser whatsoever. I tested about 5 6s aftermarket screens over 3 devices all running iOS 11. What I don’t understand is the same after market screens I tested on iOS 11 work completely fine on 6s’s running 10.X.
Has anyone else found this issue?
Is Apple clamping down on independent repairers?
Questa è una buona domanda?
Punteggio 1
1 Commento
Brilliant, thank you!
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Lorax check the answer by @refectio on here After update to iOS 11 Touchscreen unresponsive
Punteggio 3
2 Commenti:
Update 2017/10/11 - Apple just released iOS version 11.0.3 and it claims to address the Touch Failure on aftermarket screens. For those of you that have been waiting for an official fix, it appears to be here. Make sure to comment below if this update solves your problem.
da
Update 2017/10/31 - Apple has just released iOS 11.1. Check out the details here.
da
Aggiungi la tua risposta
Lorax sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 303
