Salta al contenuto principale
Help on charging port repair
My speaker wont charge and i opened it up. Once open i saw a red wire that wad not attached to anything and i cant see where it must go. The inside of the charching port had a plastic inside that also fell out. Where should the wire go and should i replace the entire charging port or can i just put it back?
Questa è una buona domanda?
Punteggio 5
10 Commenti:
You can add a different charging port.... After all it will function the same thing
da
the red cable is the antenna bru
da
How do I open the carry handle screws?
da
I also cannot get the carry handle screw off , please can you assist
da
How did you take off the 2 big handle screws on the Blaster? Cannot get the big ones off
da
Mostra altri 5 commenti
Aggiungi un commento
4 Risposte
@jolsteryes you will need to replace the charging port. Obviously it is soldered to the board so you will need to have the right tools to replace it. Check digikey.com or mouser.com for replacements. You'll need to do some searching for it but it looks like a standard connector.
As for your red wire. It looks like it is on your board so the other end will either have to go to a switch, the battery or the speaker itself. On picture number 1 it looks like there is only one wire connected to the speaker. May need a clearer picture..
Punteggio 0
1 Commento:
The read wire is the fm antenna. Leave the other end free, unconnected.
da
Punteggio 0
it is an antena for the bleutooth
Punteggio 0
Anyone got a circuit diagram on this equipment please.
Punteggio 0
1 Commento:
Anyone got a diagram for this equipment please
da
Aggiungi la tua risposta
Jolster Theron sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 32
Tutti i Tempi: 13,995
