Help on charging port repair
My speaker wont charge and i opened it up. Once open i saw a red wire that wad not attached to anything and i cant see where it must go. The inside of the charching port had a plastic inside that also fell out. Where should the wire go and should i replace the entire charging port or can i just put it back?
Questa è una buona domanda?
You can add a different charging port.... After all it will function the same thing
da Lethabo
the red cable is the antenna bru
da hicham bayed
How do I open the carry handle screws?
da hamhead
I also cannot get the carry handle screw off , please can you assist
da bradpearsall9
How did you take off the 2 big handle screws on the Blaster? Cannot get the big ones off
da bradpearsall9
Mostra altri 5 commenti
