Salta al contenuto principale
Guide per lo smontaggio e la riparazione dei computer Macintosh di Apple.
42813 Domande Visualizza tutte
Would a 7k hard drive upgrade get too hot?
Is it advisable to upgrade my hard drive for faster processing to 7k rpm?. I've seen warnings that it may get too hot. Could this damage my Mac?
I have a PowerBookG4 12", 1.33Ghz PowerPC G4, 60Gb UltraATA/100 drive (4200rpm).
1.25GB RAM, running OS 10.5.8
Questa è una buona domanda?
Punteggio -1
1 Commento
Many thanks gentlemen. You've illuminated a mysterious world for me.
da
Aggiungi un commento
3 Risposte
Naw, a 7200 RPM would about double your I/O speed of your laptop resulting in much faster startup speeds and app startups (I sound like a marketer)
Anyway, a disc gets hot under heavy use, much like your laptop. Overheating for a HDD is about 55 degrees C I believe..? and the HDD is far away enough to just cool down by itself. Keep mind mind you "Feel" that it is hot when its about 30 C and the HDD can go up to 55 C.
Interestingly though, they don't make IDE 2.5" HDDs anymore.. (link)
Refer to Mayer's post for a 2.5" 7200 RPM IDE HDD
Punteggio 2
Risposta Più Utile
The 7200 IDE drive are hard to find but here are several: http://www.google.com/products?hl=en&as_...
Punteggio 2
Many older (Before around 2005) 7200RPM HDD's can get hotter, but most modern drives tend to stay cool. I have a 7200RPM drive manufactured in 2008, in my iBook, and the computer is generally cool to the touch.
Punteggio 2
Aggiungi la tua risposta
BobM sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 743
