The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
darlenebarber54 @darlenebarber54
Rep: 1
Postato: 26 set 2017
will not print from computer
Questa è una buona domanda?
5 Commenti:
Hi,
Has it worked OK before when connected to the computer?
Does it work OK if you try to copy or scan a document using the printer's control panel?
If it works when using the printer's control panel, what make and model of computer is it connected to and what OS is installed in the computer?
26 set 2017 da jayeff
Printerhead? what do you mean? or are you trying only to print from your pc?
26 set 2017 da jbermudez27
Yes. It is not printing from computer or copy or fax
17 gen 2018 da lorenzo.walker
Hello jayeff,
It is not printing from computer, or fax, or copy. I have replaced all ink cartridges in printer
Hi lorenzo.walker,
Have you tried a 'Clean Printhead"operation from either the printer's control panel or the HP printer software in the computer?
On the printer press the Right Arrow > Setup > Tools > Clean Printhead.
Do it 2-4 times to see if it starts to print.
17 gen 2018 da jayeff
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 61
Hi,
da jayeff
da jbermudez27
da lorenzo.walker
Hello jayeff,
da lorenzo.walker
Hi lorenzo.walker,
da jayeff
