The AUX doesn't work, the Jack Socket was broken
I have a Bose bluetooth speaker II, the hole of AUX was broken, how can I fix it.
Thank you very much!
Questa è una buona domanda?
@chunxia this sounds like the AUX has come off and been pushed in. this guidewill get you to the boards. then take a couple of good pictures and post those with your question. It will allow us to see what you see. Use this guide Aggiungere immagini ad una domanda for that. Most likely soldering a new connector to it should resolve the problem.
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Guida
Difficoltà:
Difficile
6 minutes
Hi, I have the same problem: is the AUX port definitely soldered on, or is there a way to fix this issue without soldering? Thanks, Lucas
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 18
Tutti i Tempi: 1,159
