Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
touchscreen not responding... Please Help
Hey so I'm having a Problem with my iPhone 6s plus it won't respond to my Finger touch> i cleaned it , i Hold Lock and Home Button and nothing still same thing, i also Restored cause that what apple Suggested to do if none of those steps worked. Please Guys i need help on this one i really don't wanna pay a whole 500$ for a new iPhone.
Questa è una buona domanda?
Punteggio 5
3 Commenti
Has this phone ever been repaired?
da
Yes. But only the screen i took it to apple the first time, but this time i took it back to see if they can fix the Situation they told me they can't work phones that have aftermarket parts Which by the way i had order a battery from fixit.com so there was no way they could see if it was the screen or the phone
da
Hey so Yesterday i took that Screen off that i thought didn't work Cause it didn't respond. so i tested that screen on My sisters iPhone to see if it was my iPhone or My screen. so it was not my screen cause it worked.......So whats really wrong with my phone if its not the screen?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Contrary to the iPhone 6P, which had Touch controller IC's on the logic board which had a tendency to die when the phone is repeatedly flexed (i.e. Touch Disease), the iPhone 6S series (6S / 6S+), has all of the digital logic to control touch functionality built into the screen assembly.
So unless there is a power problem (still possible), the most likely solution to your problem is to replace the screen assembly. If your phone is under warranty, then you should return it to Apple for repair. If it is not, then you should look up some well reviewed, local third-party repair shops. they can put a new screen in to see if that solves your problem.
If you want to try it yourself, the you can get a replacement screen here and a repair guide here.
Immagine Replace a front glass digitizer panel or malfunctioning 5.5" 1080 x 1920 IPS LCD display compatible with the iPhone 6s Plus model A1634, A1687, A1699.
A new screen and digitizer will restore your touch functions and eliminate the dead pixels or flickering of your aging display.
Prodotto
iPhone 6s Plus LCD and Digitizer
$19.99
Punteggio 4
2 Commenti:
how do i know is the screen but not the PHONE?
da
You have to try a known-good screen to see. Either you order one or go to a shop.
da
Aggiungi la tua risposta
Vick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,850
