Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
wifi turns on and works but signal is too weak
I bought an used iphone where everything seems to work apart from the wifi, which can only find a network if it's just next to router.
I went through the guides but can't understand how could I fix this and exactly where is the antenna responsible for the wifi signal power. Thanks in advance for any help you can provide
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
iPhones, unlike Samsung phones, are very hard to get into and repair. If you really wanted to give it a go yourself, you can buy a new antaenne on IFixit for 14.00 and try to replace it. The antaenne is located in the top of the phone. (The anatanne for wifi and cellular service are different parts) If you don't want to go through that and risk messing up your IPhone, you should probably take it to a professional repair place.
Punteggio 0
1 Commento:
Can you show me the picture or link for the part? Are you sure it's the top one? Cause there's another wifi part in the bottom, also said to be an antenna according to the guide, called wifi diversity antenna
da
Aggiungi la tua risposta
Zed Mendes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 62
