Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
Playstation 3 controller issue
my controller is not working after yellow light repair, it turns on and stays on but controller doesn't work ,tried reset and 4 different controller but nothing , could I have a loose cable or something? PS3
Questa è una buona domanda?
Punteggio 0
1 Commento
woody99 sounds like a bad controller board inside your PS3
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi woody99, you can try with another cable, else if possible get a thumbdrive or misc, connect it up and check on your PS3 if it is able to detect it.
Punteggio 1
the small ribbon cable doesn't seem to go in correctly and it may be damaged, could this cause my problem? you say controller board , I only see blue tooth board and power reject circuit board, what is the part number and do you carry that part and ribbon cable?
Punteggio 0
1 Commento:
Hi woody 99 just take some pictures for us to have a look
da
Aggiungi la tua risposta
woody99 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 129
