Salta al contenuto principale
Bose's consumer range of active noise-cancelling headphones are called "QuietComfort".
21 Domande Visualizza tutte
Source for procuring quality replacement speaker for QC25
I have the same problem as described here: How toReplace broken speaker for QC25.
In short, the speaker on my right died.
The question is where to buy the replacement part. It seems that this part is available on eBay for a range of prices, which warns me for cheap replacement parts.
I am looking for a source for a quality replacement part, in order not force me to replace (=downgrade) the other, currently working side at the same time.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@asdmin the only way to get the guaranteed right working speaker is through Bose itself. Contact them and see how much the repair would be. Anything else you'll take a chance but you may just get a good replacement. You can also purchase a complete set that is broke, other than the speaker, and then harvest the speaker from that.
Punteggio 1
2 Commenti:
Thanks, the suggestion for a broken unit was very helpful!
da
Before I blew the headphone up, I called Bose. They will replace mine, as it was affected by a manufacturing defect. Nevertheless your answer is correct and valuable. Now given, that this headphone is serviceable, I'll also look for a broken one for parts. Thanks!
da
Aggiungi la tua risposta
Daniel Vasarhelyi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,600
