Salta al contenuto principale
Numero modello A1707. Rilasciato a giugno 2017, questo MacBook Pro adotta processori Kaby Lake fino a Intel Core i7 quad core da 2,8 GHz con Turbo boost fino a 3,8 GHz.
Damaged case, everything works. How much $ to fix?
Dropped on R corner. Upper case, lower case and screen case bent. Top and bottom separated. Speaker damaged. Have apple care but not +. Too late to add + and too late to get credit card to cover damage. What will it take to replace cases? I know-lots of $, but where, when and how can I find, purchase and replace these damaged parts?
Everything else works perfectly and no damage to the screen itself. Dropped from only 1-1/2 foot.
Questa è una buona domanda?
Punteggio 0
1 Commento
[image|1191605][image|1191602][image|1191604]
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I'll give it a try
Punteggio 0
Risposta Più Utile
Getting parts at this time will be nearly impossible. Until
they become available, use an add on plastic hard case
Punteggio 3
5 Commenti:
I forgot, if a machine is still covered under the original warranty, you can still buy an extra two years worth of Apple Care.
da
Thanks for the reply. After looking at the tear down for this unit I'm not sure I even could replace the damaged case halves and the screen lid if the parts ever become available. I didn't imagine dropping it in the 1st place so no AppleCare +. Just a very unlucky hit and a cautionary example of how vulnerable these units are to major damage from a small inadvertent moment of inattention. But, again, everything still works. I'm glad of that.
da
mikenmary8 If you would please post some pictures of the damage so we can better evaluation the extent of the damage, how much is cosmetic and what it would take to get it functioning correctly.
da
I've got some good pictures but I don't know how to add them. I've explored the site looking for some instruction but to no avail.
da
Aggiungi la tua risposta
mikenmary8 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,318
