Repair damaged card slot, get card error, when card was put into slot.
Card sticks in slot. Will not come out without force. Can slot be replaced? Email address: hendersonc14@yahoo.com.
Questa è una buona domanda?
The SD card slot can be replaced by soldering in a new one. You can find SD card slots on digikey / mouser. Make sure to check the PCB pad dimensions for the broken sd slot and the replacement one. Also, make sure you are using the correct tips on your soldering iron, and that it is powerful enough for desoldering.
An example of a replacement microSD slot:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 104
