Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
43 Domande Visualizza tutte
Ear piece Speaker quiet?
Replaced cable and speaker. Originally broke for no reason, just went quiet one day. No water damage. Tried new battery and soft reset. Help??
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
A lot of times it's caused by a build up of dirt and grime in the speaker mesh. Replacing this solves the issue 9 out of 10 times.
If you can, Hold the LCD screen up to a light source and try to look through the ear speaker mesh. If you can see the light through it then its clean, but if it's blocking the light, or only allowing only a little bit of light to pass, chances are you need to replace it so that you can improve the sound quality.
Punteggio 0
Aggiungi la tua risposta
Austin Harris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,953
