Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Voice Memo Microphone not working
Customer has brought in a device. The customers Voice Memo or snapchat if you attempt to record is just crackly. We have tried a Front Camera Flex & Powerflex (with rearmic built in) and still no sound. New earspeaker mesh also. Any suggestions please
Questa è una buona domanda?
Punteggio 2
1 Commento
Were you able to fix this? I have the same problem.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
There are 3 microphones in the iPhone.
https://support.apple.com/en-us/HT203792
  • The bottom microphone is for Voice Memo and phone calls. The other microphones serve as error cancellation
  • The (top) front microphone is used for FaceTime calls, Siri and selfie videos with the front camera (FCAM). The top back microphone serves as error cancellation
  • The (top) back microphone is used for videos with the rear camera (RCAM). The top front microphone serves as error cancellation
Make sure you update your device to the latest version of iOS and then try to isolate which microphone is not working properly by trying each individual microphone with the related apps above. If the issue affects more than one microphone, then it could be the Audio Codec IC on the logic board.
Anything at the logic board level will require micro-soldering so you would need to find a repair shop that offers those services.
Punteggio 2
1 Commento:
I have the exact same problem, and this solution is not really a good one as calls work fine but the voice memo app does not.
da
Risposta Più Utile
i dont think this is an hardware issue.
iam on ios 11.4.1 iphone 6s
  • memo and 3rd party memo recorder r - just static sound
  • phone calls on speaker -fine
  • phone calls normal - fine
  • front cam - fine
  • backcam - fine
so the one and only thing not working is anything that ask for acess to microphone which is wierd.
Punteggio 3
2 Commenti:
I have the same problem except that phone calls fade out , i think it’s software because many users reported that they replace the mic and didn’t solve the problem
da
I have the exact same symptoms as you. Not finding any joy so far. Have you figured this out?
da
Hello! Seems like the microphone was damaged. Have you tried to replace it?
Punteggio 0
1 Commento:
I have replaced the microphone flex at the bottom but it didn't help. The front and back video records the audio just fine. Sometimes the audio over a phone call also sounds like it's static. Have messed around wih the software to determine it's not a software related issue.
da
Aggiungi la tua risposta
Phone Repairz NE LTD sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 26
Tutti i Tempi: 25,989
