Salta al contenuto principale
Repair guides and support for your Samsung TV.
2614 Domande Visualizza tutte
My tv turns on but when screen comes on the words are doubled.
The words are like a split image. Like this- Weak or NO Signal
Weak or No Signal
Except that the bottom words are lighter and they are flickering. Where would the problem be located? When I go to the menu the pictures are doubled also.
Questa è una buona domanda?
Punteggio 0
1 Commento
@neil56 what is the exact model number of your TV?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
@neil56 if it looks something like this
Then it is a GATE TAB Bond failure on your panel. Check on the thin ribbon cables that enter the side of the panel. See if you find some corrosion or other damages to it. Sometimes a bit of pressure on those cables (try the top left side of the panel) can help to correct it for some time (fixed one with duct tape :-)
Here is a great image of the TAB's
from here.
The only permanent fix is replacing the panel. If unsure where to look and what to check, post some good images of your panel etc. with your question. Use this guide for that.
Punteggio 3
That is a symptom of a bad LCD screen.
Punteggio 0
Aggiungi la tua risposta
Neil Long sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 269
