Salta al contenuto principale
The Astro A40 TR Plus Mixamp M80, manufactured by Astro gaming, is a headset and amp bundle used to increase the stereo sound quality for the Xbox One .
Is the device compatible with other XBox devices?
Solely, XBox 1 system?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Sort of! There are two devices and one is compatible (to a point) while the other is not.
The headphone portion of the headset will work with anything that has a 3.5mm TRS or TRRS port (headphone jack) but the microphone will only work if the port supports a CTIA TRRS connection. The Xbox 360 controller port does not support the microphone but it does support the headphones.
The Mixamp M80 only works with the Xbox One. Perhaps there is a workaround, but the Mixamp M80 was designed for the Xbox One system.
Sources:
http://forums.astrogaming.com/index.php?...
Punteggio 0
Aggiungi la tua risposta
Loretta Sohappy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 181
