Hello All,
I have run a small repair business for 7 years now. I pride myself on quality work, so when I began to have about a 20% return rate for phantom touch issues I knew I had to dig my heals in to try and figure this out.
First thing first - I do not use OEM displays. All my displays however are high quality copy with TIANMA LCD’s and I have used the same supplier and same quality level for years without issues.
I’ve come up with the following procedures during iphone 7/8 repairs and have not had a single return since. I’ve also done these procedures on returned units with the same display and fixed the issue.
First - the Metal rectangular cover on the flex cable of the new screen has to be positioned perfectly. The best way to determine the position is to take a pair of calipers and measure from the frame of the phone to the edge of the loudspeaker. For example, the Iphone 7 measures 30.50mm and the iphone 7+ measures 44.50mm. I use a piece of kapton tape to hold the flex cables in place, measure from the edge of the screen to the edge of the cover, adjust, measure etc. Once you have it where you want it, install the metal backplate. If you make the actual position of the edge of the rectangular cover match this distance within +0.2mm/-0mm you’ve completed step 1.
Second - I’ve noticed that on the original displays, the rectangular chip cover is one solid piece covering all the critical components on the flex. The chips installed on the aftermarket units are wider then original, and they have made these fit under the cover by cutting the edge of the cover leaving the chip exposed. If yours are the same as described, cover this exposed chip with a piece of Yellow Kapton tape.
Third - When installing the screen back onto the phone, install all 4 screws in the flex cable cover loosely. Side the metal cover upwards as far as you can with all 4 screws loose. When you have it as far upwards towards the top of the phone as you can, tighten the 4 screws.
I’ve got photos of all the critical steps if anyone would like a copy, send me a message,
Votato
Annulla
Punteggio
3
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
5 Commenti
I have an Iphone 7 with similar issues. Everytime I would play a game, certain presses made other areas of the touch screen to be pushed! I tried everything, from switching screens , even thought about swirching digitzers. I finslly FIXED IT with the use of ELECTRICAL tape. I put electrical tape on both sides of the Iphone after Opening it , making sure that no metal parts were visible, and IT WORKED! the ghosting issues are Nonexstent. Its most likely that a loose screw fell under the motherboard causing an electrical shortage, .
da Choyy Mengg
hello Choyy Mengg can i know how to put the tape on the both side of the iphone
da Mohamad Afif Suhail
I had this problem for like 5 days where my touchscreen would just press on random things that I wasn’t pressing and it was unresponsive. But it got fixed out of nowhere. One day it randomly stopped doing it and it hasn't happened ever since.
da Amir Zand
@Amir Zand And how is that helpful?
da Hunter Desborough
"Makabu-ang ni nga problema". This is what I did and I already shared it to my Manager to confirm if it still works on his iPhone unit.
1.) If your affected iPhone unit has with tempered glass already then please remove it.
2.) Clean the touchscreen from any printed marks.
3.) Temporarily attach clear scotch tape on your iPhone's whole touchscreen. It's okay if it overlaps each other because this is just to test.
4.) Perform testing.
5.) If you think your problem is gone then remove all the scotch tape, clean then find plastic type screen protector then let expert guy to attach it onto your touchscreen.
6.) Much better if you attach first the plastic type screen protector then cover it with the glass tempered. Maybe by this you'll know also what's the cause of this specific annoying problem of iPhone units. Worst case also is defective LCD or touchscreen.
That's all for now and maybe it helps to solve your problem.
To God be the Glory.., all the time!
da Edil Villacorta
