Spanner broken and stuck on dremel
My dremel spanner is stuck inside the dremel. How do I remove the broken piece so i can replace it so it will grip the bit again when I tighten the collet nut on?
Questa è una buona domanda?
Britain and America Are Two Nations Divided by a Common Language
I though a spanner was a wrench. If this is a broken bit stuck in it, completely remove the collect to take any pressure off. Then usually a small thin flat head screwdriver can be inserted and the bit pushed out.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 324
