Salta al contenuto principale
La famiglia MacBook è stata introdotta nel maggio 2006, sostituendo l'iBook nel ruolo del laptop Apple indirizzato al mercato consumer.
3787 Domande Visualizza tutte
Domanda Chiusa
How diagnostic from usb key?
Think my logicboard is dead, black screen, just HDD who is power on nothing else, opical drive do not respond at all
How to realize an hardware diag from external usb key cause to put "D" key at startup do nothing
thks
Questa è una buona domanda?
Punteggio 0
3 Commenti
I'm not sure I understand. Your symptoms point to a dead logic board, but what are you attempting with USB?
da
With 24h, no changes, I have power cause I can heard the Hard drive power up
Think its logic board definitivly
thx
da
yes and no chime even if I keep power button on during a while...
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
Grasping at straws here...
You could try removing the battery, unplugging the power, and letting it sit for 24 hours and see if that brings it back to life.
I assume you're not getting the startup chime? If you are, there are other steps we could offer.
Have you considered it may not be getting enough power? Do you have access to another power adapter to try? Try it without the battery installed.
Punteggio 1
I hope an usb diagnostic tool in order to confirm if logic board is dead or not cause I m not confortable to buy another logic board just for fun !
Punteggio 0
1 Commento:
Unfortunately if the logic board is bad the USB ports most likely will be dead. Ralph
da
thx
Punteggio 0
1 Commento:
No chime? Just hard drive spinning?
da
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 913
