Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
773 Domande Visualizza tutte
How can I Remove the Battery from the Top Case?
I have seen answers suggesting that I use methanol to remove it, but I am not sure I will be able to find that locally. I am wondering if I can use a different sort of alcohol to remove the battery.
Thanks in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Here's the guide on doing it. I use methanol, any high grade (low water) alcohol will work:
Sostituzione batteria nel MacBook Pro 15" Retina Display versione metà 2015
Punteggio 3
3 Commenti:
I was hoping you would give your opinion on this, as it was your posts I was referring to for this repair. Thanks for posting this guide. I took a brief look at it yesterday, but decided to wait until I knew for sure that I could use something other than methanol!
da
I use methanol because it is pure with no water.
da
iFixit uses acetone in their kit.
da
Risposta Più Utile
Yes, you can use 95%+ isopropyl (rubbing alcohol) and a thin tool to remove the battery; it allows the tool to slide under and cut the adhesive holding the battery to the palmrest.
Punteggio 4
2 Commenti:
Awesome! Thanks for the help! I wasn't sure if there was a particular reason to use methanol, and didn't want to risk it given my virtually nonexistent understanding of the chemistry involved with Li-Ion batteries.
da
this is a great fix - done it on phones, iPads, and especially MacBooks where the battery can be a real bear. I haven't found 95% but my 93% does the trick - and if you let it dry, the adhesive strips get their tackiness back in a couple minutes and can be reused too.
da
Aggiungi la tua risposta
Noah Theobald sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 912
