Salta al contenuto principale
Some keys are not working.
I have a HP Pavillion 15-p020nd and some keys are not working. These are the keys that are not working :
. I think this is a hardware problem. I have pend the device to check the flatcabels but they looked fine to me. Does anybody know what the problem is are do i need to replace the keyboard?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@peha72 try an external USB keyboard and see if that works. If so, you most likely will have to replace yours. this link should work for your laptop.
Punteggio 1
3 Commenti:
Hi Oldturkey03 thanks for you reply. I have tried an usb keyboard first and that worked fine. So you think I have to replace the whole keyboard?
da
Usually this is associated with a liquid spill.
da
@peha72 yes it does look like it. I would definitely replace it.
da
Aggiungi la tua risposta
Peter de Hart sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 487
