Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
Why is my battery meter unreliable below 60%
Sometimes my battery meter stays long at a particular percentage, and then quickly drains 2% or 3%. So I'll be on 50% for about five minutes, and then quickly drain to 49%, 48% in a minute, and then stay at 47% for a longer time. The battery seems fine but the meter is unreliable.
Questa è una buona domanda?
Punteggio 0
4 Commenti:
What did you try to do already? Reset? Anything changed on the phone?
da
I've done a Factory reset, but it's still the same
da
Factory reset as in restore on iTunes?
If yes, check battery health using either app battery life on app store, 3Utools (Windows desktop application) or Coconutbattery​ (Mac OS X).
If you see near or under 65% consider replacing the battery.
Battery % fluctuating going like that is usually a bad battery too.
da
No I didn't restore form iTunes
The battery capacity is 93%. 7% wear level.
da
Aggiungi un commento
1 Risposta
Replace the battery or buy the Apple Smart Battery Case
here is a link to the website https://www.apple.com/au/shop/product/MG...
Punteggio 0
Aggiungi la tua risposta
enasowah sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 126
