Salta al contenuto principale
Il robot aspirapolvere iRobot Roomba 655 Pet Series prodotto nel 2012. Esclusiva Costco.
Side brush isn't working.
The side brush isn't working anymore. I've replaced the entire side brush unit and it will do a .25 revolution once it starts cleaning then the side brush will not work. I've striped it down and cleaned everything that could be cleaned. I am At a loss here no idea what's up and I-robot told me to buy a new one when I called the help line.
Questa è una buona domanda?
Punteggio 0
1 Commento
Did you solved the problem? I have the exact same thing, replaced the module, still not spinning :-(
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
@bobo006, Ben, If you have already replaced the side brush motor and still not working, check the wires and connector for being, loose/damaged/corroded/check the connector with DVOM to ensure power is getting to the motor and make necessary repairs if defect found. If motor has not been replaced perhaps consider replacing motor. 1st link below is a guide to replacing side brush motor and 2nd link will get you inside to inspect the mother board for loose/damaged/burnt components. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Sostituzione del motore della spazzola laterale iRobot Roomba 655 Pet Series
Sostituzione scheda madre iRobot Roomba 655 Pet Series
Immagine iRobot Roomba 655 Pet Series Scheda madre
Guida
Difficoltà:
Difficile
2 - 3 hours
Immagine iRobot Roomba 655 Pet Series Motore della spazzola laterale
Guida
Difficoltà:
Moderato
10 - 15 minutes
Punteggio 2
2 Commenti:
My roomba side brush remains on. This happened after my roomba got wet. What can I do?
da
Be sure the central screw on the brush is not too tight. Even though you can turn it with your fingers Roomba will detect a TANGLE if its too tight and shut it down.
da
Aggiungi la tua risposta
Ben sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 11
Tutti i Tempi: 4,375
