Salta al contenuto principale
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Domande Visualizza tutte
water on trackpad not working
I had a bit of water falling on the trackpad and now trackpad and keyboard are not working. with external usb keyboard and trackpad all is Ok.
do I have to change the trackpad, or only some ribbons?
thanks for the help.
serge
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
I had the same problem last summer on a 2012 and it turned out to be a software fix. This was a tough one. Here's my Q & A on it: Trackpad Does not Function Properly
Punteggio 3
This model uses a pass-though design where the keyboard is connected to the trackpad and then the trackpad and keyboard signals are forwarded to the logic board with a single connection.
So with both keyboard & trackpad dead it will either be the trackpad its self or the ribbon cable from the trackpad to the logic board that will need replacing (or both). Review this IFIXIT guide here: MacBook Air 13" Mid 2013 Trackpad Replacement
Here's the parts you'll need:
Immagine MacBook Air 13" (Mid 2013-2017) Trackpad
Prodotto
$49.99
Punteggio 2
2 Commenti:
thanks a lot. I will try first to remove the trackpad and dry it well.
da
This is probably the best solution in my opinion.l
da
Aggiungi la tua risposta
serge sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 149
