Salta al contenuto principale
Repair information and support for walk-behind lawn mowers made by the Toro Company.
Why is the engine over revving?
With the engine running the governor doesn't seem to be controlling the engine rpm's and over-speeding. Throttle control cable doesn't seem to be controlling the engine
speed whatsoever.
Thanks, Tom of Indy.
Questa è una buona domanda?
Punteggio 1
2 Commenti
What model is your mower? Is it ride on?
da
tjcox6841 anything related to engine adjustments etc. will be in the Tecumseh manual. Let us know if you can find any model number or other indicator on the engine.
My cross reference shows that your mower should have a Tecumseh TVS840-8014B
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
tjcox6841, Tom, You did not state your engine or model #, so I will post some what generic answer. Sounds like the governor linkage may be stuck, broken linkage/spring. Look for dirt/debri around the governor linkage and wash/brush/blow any debri from linkage and ensure linkage mechanism is intact and hooked up and throttle cable is still hooked up and not broken/seized on. Links below may be of some assistance. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=shgawgDT...
http://www.hobbytalk.com/bbs1/110-small-...
https://www.youtube.com/watch?v=EVIZtyw3...
https://www.google.ca/search?q=tecumseh+...
Punteggio 6
9 Commenti:
Toro Model #26551 tecumseh two cycle engine.
da
Governor linkage is free ,however I believe the adjustment may have been changed.
da
@pccheese when you vote an answer down, it polite to state why you did it. Why did you vote this down?
da
@mayer Oh, pure accident. I ment to vote it up.
da
@mayer , @pccheese Thanks, I was scratching my head on this!
da
Mostra altri 4 commenti
tjcox6841 here is the description from the manual for the TVS series engine. Let us know if this looks like what your engine uses. If so, I can probably provide you with the rest of the manual, but cannot post it due to size limitation. Post some images of your engine, your carb and your governor linkage etc. Use this guide to do so. This will allow us to see what you see.
Punteggio 2
Aggiungi la tua risposta
tjcox6841 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 42
Tutti i Tempi: 53,365
