Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Home button connector part number?
I yanked the home button out of an iphone 6s to use for a project. And I wanted to know what the connector at the end of the flex cable is. A type would be great and a part number would be even better. Im a MechE so electrical engineering is still somewhat basic for me. I noticed the connector has I think 14 contacts total? it looks like 5 sets are used for signals and the other 2 sets might be for ground/power supply. Any help/insight is much appreciated! thanks!
Questa è una buona domanda?
Punteggio 0
3 Commenti:
Is it the cable coming from the home button itself, the long cable that is attached to the large metal plate behind the screen or the connector on the board that connects to the home button extension cable?
da
Its the one that is coming from the home button cable itself...NOT the long flex cable that it attaches too which goes to the large metal plate. But that one would work too I would think because it would be its mating connector.
da
Does anyone have any thoughts?
da
Aggiungi un commento
1 Risposta
The home button part number should be the one on the bottom of the cable sticking out of the side of the home button. It is fairly large and you should be able to see it easily.
Punteggio 0
1 Commento:
Thanks for responding. I was hoping to get the connector part number (or at least type of connector), not the home button part number. The number on the flex cable gives me the whole assembly but not the connector component.
da
Aggiungi la tua risposta
tim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 49
