Salta al contenuto principale
Il Toshiba Satellite P775-S7320 è di colore nero con un coperchio testurizzato che presenta un logo Toshiba argentato lucido al centro. Il portatile include anche un poggia polsi resistente alle impronte. Questo modello è stato rilasciato nel 2011.
Computer turns on, but it doesn't?
I turn on the computer and fans spin, it makes noise, hard-drive starts spinning up, and then nothing. Nothing pops up on screen, (Screen is NOT broken as I tested that first with a HDMI cable) so my guess is that the BIOS needs to be reset... but Toshiba doesn't exactly help with any of this by not have public schematics or even guides on how to fix it, I called their tech support and they wanted 20$ USD just to talk to them. So I turn to the internet now.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
Unplug the power cable, remove the battery and hold the power button for 10 seconds.
Let me know if this helps?
Punteggio 2
Hello,
IT PRO here.....
Now to get this straight here you did test the HDMI port... fan and everything comes on..
It sounds like the LCD itself is dysfunctional. Which is the screen on the actual lid of the laptop.
The HDMI cable you plugged into the laptop ties into graphics card which bypasses the screen itself all together.
It seems like you will be in need of a replacement LCD.
Let us know if the battery unplugging worked otherwise you will have to replace the screen.
Punteggio 0
Aggiungi la tua risposta
Jason Epperson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 13
Tutti i Tempi: 487
