Picture does not allign
After the camera was dropped the picture on the screen is moved about 1/2 frame. Any way to correct the alignment to center frame again
Questa è una buona domanda?
@hotcana there is really no adjustment on the LCD screen. It looks like the driver board is off. I would open the camera up and see if the display cable is fully seated and straight inserted. If it is, then consider replacing the LCD. Again, you cannot do an individual adjustment on it. This should help you with your repair DMC-TZ5 SM
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 44
2 Commenti
@hotcana post an image of what you see on your screen. It'll help to see what you see....Use this guide Aggiungere immagini ad una domanda for that
da oldturkey03
Thanks, old turkey, I will look into the cable connections that makes sense I think after the camera dropped
da klardie
